This secession is especially for newbies, so proudly present my silly question, with respect to all those expert out there. LOL
I have avi file, its damn huge 3.58 gb, I did try to author it in dvd format with couple of programs, but they stop claiming “the data is huge” .
Question is, what should I do?
With thankful heart
Results 1 to 9 of 9
First, drop it into Gspot 2.60 and report the information. What type of AVI is it first? There are probably a hundred variations of 'AVI'. And what is the running time of the AVI? For quick and easy, try ConvertXToDVD.
A Gspot screenshot would be helpful. Blank out the title. How to here: https://forum.videohelp.com/viewtopic.php?t=271697
Generally a Xvid or similar of 3Gb or more would be unusual, unless it's a HD video.
Originally Posted by redwudz
Sorry its not avi, but mpeg, my mistake. actually i had also problem authoring avi files and i took this as mistakenly. once again sorry.
So, what you can say about it to authoring in dvd. ??? -
It's already in DVD format mpeg2 so shouldn't need anything doing to it. What software are you using to author as it should just be accepted as compliant.
One simple way with 2 free apps:
Get Rejig.
Click "file mode".
Demux the file to m2v (video) and AC3 audio.
Exit
Then click "DVD Author"
Select the 2 files you just made,
select a destination folder, "Create".
This will create a VIDEO_TS file set.
Exit, Quit.
Now use a burning app, like ImgBurn:
Build mode, select the VIDEO_TS folder you just made. Burn. -
I was using NERO and UDF ? and both are not accepting it.Originally Posted by Richard_G
thanks, i will try this, and let you know. thanks once again.Originally Posted by AlanHK
Mate, its works perfectly..... i did burn vobs with dvd shrink, thanks for your great help.Originally Posted by AlanHK
Cannot Play A HUGE BD Folder
By niteghost in forum Software PlayingReplies: 8Last Post: 12th Mar 2012, 19:47 -
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 18:53 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
Huge Hard Drives (again)
By ahhaa in forum ComputerReplies: 8Last Post: 28th Dec 2007, 03:04 -
Huge Problems With Vegas 7.0 and 8.0
By Cunhambebe in forum Newbie / General discussionsReplies: 12Last Post: 23rd Dec 2007, 20:36
