I'm looking to extract a several minute segment of a DVD (non-encrypted) to my hard drive as some kind of easily shared format (XviD AVI or MOV would be ideal). My question is, is there anything out there for OS X 10.3.9 that will allow me to manually set in and out points for the clip that doesn't require me to shell out for the MPEG-2 decoder?
I know MPEGStreamclip will do it if you've got the MPEG-2 component, but I haven't had the greatest luck with Streamclip and am hesitant to shell out for the MPEG-2 add on only to have Streamclip not work the way I want it to anyway. What I'd love is something like HandBrake that allowed time code in and out points rather than just chapters.
Is there something out there I haven't found? Alternatively, can someone reassure me that it's worth the $20 for the MPEG-2 add on to use with Streamclip?
I can assure you the Mpeg-2 codec addon from Apple is well worth the $20,Originally Posted by canaim
as not only does MPEGStreamclip rely on it, so does Quicktime Pro.
Relating to MPEG-2 files, there hasn't been anything I couldn't do
I needed to do, with these two apps and that component.
Your choices:
$20, no headaches.
Free, but you spend a lot of time in forums hunting and trying
different "free" fixes and tricks, and you gain a lot of headaches,
plus waste a lot of time, trying to get something simple done.
your call...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks for the suggestions. I'm definitely going to just get the MPEG-2 decoder, since it's not like $20 is going to break me and every other possible solution has had me going in circles. The only reason I didn't just do that in the first place is that MPEGStreamclip has been a bit buggy for me and I didn't want to get the add on, only to have it be more of a headache than it's worth.
I'll second the suggestion for the MPEG2 codec and MPEG Streamclip. Probably not a bad idea to also get Perian (if it works in 10.3.9; I forget) in case you encounter other codecs.
Recommended dvd authoring software with manually chapter function...
By Conrad007 in forum Authoring (DVD)Replies: 14Last Post: 27th Feb 2011, 13:54 -
Best DVD Ripping Setting????
By laithmeister in forum DVD RippingReplies: 3Last Post: 7th Jun 2010, 04:57 -
Manually ripping subtitles from TV shows
By encodedprocess83 in forum SubtitleReplies: 5Last Post: 7th Oct 2009, 16:50 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 09:16 -
DVD Decrypt segment extraction
By kippard in forum DVD RippingReplies: 6Last Post: 24th Feb 2008, 23:30
