Hi all,
Ok, on sunday night there is a sports even that i want to record and its 3 hours long. DOnt think there will be any adverts but id like some flexability to change the thing.
What do people suggest that I capture in for a good 3 hour capture. Ideally I wante to be able to split the event up onto 3 discs to watch at a hotel where Im working (so i think this rules out asf)
Hardware..xp1600 machine. 512mb ram, 20gig disk (not that much free tho) and a Wintv pci card Any help appreciated
With a 20GB HD (and no space free) 3hr capture is unlikely
Try PICVideo with a high setting and low resolution, quaility will go down but that's the only way I see this working, sorry...
Hi, this is Chris,
Why do you want to record a sports event on the computer? Why not using a VHS VCR? If you must record the sports event on the computer, the WINTV program is too big to record anything on a 20GB empty hard drive. The program is using .avi video file, an 8 minute clip would take 1GB of space. I might be wrong, is the program using MPEG2?
I have managed to record a full movie into the hard drive myself, 2 hours of it. I was using the video card in the computer from the video player. The hard drive space used was only 2.2GB. I was using the program, Guillemot DVR with capturing file, mpeg2. The video resolution of mpeg2 is not the best for full screen viewing.
You must get a better video capturing program such as PowerVCRII or some other compressed video-capturing program. Sorry, I can't do more for you. -
Reason is that i have a laptop and want to take stuff on the road with me. If I can work out why Windows Media Encoder wont pick up a tv channel then i might be onto a winner with that Managed to capture hours of stuff using a 800 bit rate with it..
Capturing with VirtualDub - File size 400GB and only 2 hours from old rec
By Diegovh1 in forum Capturing and VCRReplies: 15Last Post: 28th Jan 2012, 07:40 -
Compressing 30+ hours of video to 10 minutes?
By nerys in forum EditingReplies: 5Last Post: 8th Jul 2010, 06:49 -
Help! I need to encode 60 hours of video fast ...
By seminarsondvd in forum Video Streaming DownloadingReplies: 2Last Post: 21st Mar 2009, 16:54 -
Two hours of video over 7 GB MPEG?
By Canopus Smoker in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2008, 22:21 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23
