Hi guys, I have an mpg film of which I only require a specific sequence from, what is the best freeware tool for doing the splitting?
Basically, I want to take this section of mpg and burn it to disk without having to encode the section of the film again?
Results 1 to 9 of 9
Best, cuttermaran. But you must demux the video and audio first.
https://www.videohelp.com/tools?orderby=Type&s=107#107
If you think demuxing is too much work buy VideoRedo.
Cheers Baldrick, demuxing isnt a hassle, I just didnt need the time consuming encoding headacheOriginally Posted by Baldrick
If I have to demux the video/audio before splitting, how much of a pain is it to avoid much in the way of sync problems with Cutterman?
Yep, you can first try it first...but it's not free for mpeg2 video and it's very buggy.
While TMPGEnc does cost (after trial period) for MPEG2 encoding use, IIRC the cut/merge tool is still fully functional (along with MPEG1 encoding). And I neve had any difficulty with it at all for simple cuts (although I almost always would have been cutting on closed-GOP boundaries).Originally Posted by Baldrick
Scott -
Wow.
Well, I've had the Plus (registered) version of TMPGEnc for quite a while now, so I guess I could be wrong. I am sure about the MPEG1 though, maybe it's just any MPEG2.
Even so, I'd still give my vote to Cuttermaran for these kinds of jobs. There are other muxer/demuxer utilities out there...
splitting wmv and mpg at time codes
By silverbullet69 in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2009, 03:42 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 13:47 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 22:32 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48
