    Feb 2007
    Ok so i downloaded the demo version, i'll get the full version if i can get this demo version working.
    So when i goto burn the dvd it tell's me i need to goto settings and choose a burning device or something.
    I click on settings and get this error come up
    "An unhandled exception has occurred in your aplication"....it goes onto say
    "NeroAPI was not intialized or was unsuccessfully intialized.Makes sure that all relevant properties are filled in.Check "Lasterror" property for possible errors"
    Then here are the details
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Runtime.InteropServices.COMException (0x80040201): NeroAPI was not initialized or was unsuccessfully initialized! Make sure that all relevant properties are filled in. Check "LastError" property for possible errors.
    at NEROLib.NeroClass.GetDrives(NERO_MEDIA_TYPE lVal)
    at x3284ccece41ee22b.x753c147d603aabe6.xf224c03044d5d 4e1()
    at x3284ccece41ee22b.x753c147d603aabe6.get_xaa807afed 8dd2568()
    at x3284ccece41ee22b.x58ff75059d7bf794..ctor()
    at x3284ccece41ee22b.x210ff09a2516b1a7.x6341f549d2d05 feb(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at DevComponents.DotNetBar.DotNetBarManager.OO(BaseIt em 6GR)
    at DevComponents.DotNetBar.BaseItem.RaiseClick()
    at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
    at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
    at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
    at DevComponents.DotNetBar.GenericItemContainer.Inter nalMouseUp(MouseEventArgs objArg)
    at DevComponents.DotNetBar.Bar.OnMouseUp(MouseEventAr gs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.Bar.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.1.2474.0
    Win32 Version: 2.1.2474.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2%20DEMO/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Assembly Version: 5.9.0.0
    Win32 Version: 5.9.0.2
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2%20DEMO/DevComponents.DotNetBar.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    Accessibility
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Interop.QuartzTypeLib
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2%20DEMO/Interop.QuartzTypeLib.DLL
    Interop.DexterLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2%20DEMO/Interop.DexterLib.DLL
    System.Management
    CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
    Interop.NEROLib
    Assembly Version: 1.4.0.0
    Win32 Version: 1.4.0.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2%20DEMO/Interop.NEROLib.DLL
    Microsoft.VisualBasic
    Assembly Version: 7.0.5000.0
    Win32 Version: 7.10.6001.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  2. install neroburner https://forum.videohelp.com/viewtopic.php?t=222190
    you will also have to install nero.
  3. I missed that this was on the demo. Did you try to set it for Nero or does the error occur when you choose the settings dialogue? Can you make a choice in the settings area for burning?
    I would recommend you use ImgBurn as it gives better and more consistent results (and is free).
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
