I burn VCDs and play them on my PC through PowerDVD and they sound wonderful. I take that same CD and try to play it on my Pioneer DV440 component player and the audio is filled with gaps and pops to the point where it is not watchable. The VCD discs that I am burning are converted from Divx AVI using TMPGEnc and VirualDub and then burnt. Every single burn I have done so far sounds great on my PC but terrible on my component player. What is ever more mysterious is that I downloaded a movie off the internet ALREADY in VCD format. All I had to do was burn the BIN file to a CD. That particular burn sounds fine on my component DVD player. WHY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Why do the VCDs that I create from Divx AVI files sound great on my PC but terrible on my component DVD player? I am about 2 seconds from losing my frickin mind and I could really use some help!
How are you encoding your VCDs? What resolution, bitrate, etc. are you using? My first thought is that you have a xVCD disc that your stand alone doesn't like.
Make 100% sure that you have encoded the VCD audio to official specs.
Otherwise your player will have playback troubles.
AVIs to DVD - Video fine, no sound ...
By CaptainChaos in forum Authoring (DVD)Replies: 9Last Post: 18th Jun 2010, 20:13 -
WMP 10 won't play CD's the audio is all choppy sounding, mp3's are fine..
By J Tinsby in forum Software PlayingReplies: 3Last Post: 14th Dec 2009, 06:32 -
uTube Issues?? Choppy Video playback but sound is fine
By sandman423 in forum Video Streaming DownloadingReplies: 2Last Post: 14th Oct 2008, 16:47 -
Choppy Sound and Fast Video
By MannyNoela in forum Capturing and VCRReplies: 10Last Post: 23rd Apr 2008, 15:29 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 12:09
