Hopefully a very easy question to answer: searced for the low pass filter - but came up with nothing useful.
Been looking at CCE SP trial - under the QUality Settings there are some settings I am not familiar with. Anyone able to explain what they are and what effect they have on the output.
(FYI - trying it to convert captured tv episodes and convert to DVD)
1. Low pass filter? - has settings from 2 to 10
2. Effect restricted Vertical Filter? - settings from 1 to 128
3. Dithered quantization? - has settings from 1 to 128
If anyone can explain what they do - or point me to a link that describes them.
Many thanks. eon
Hi-
It's all in your manual.
The low-pass filter filters out high frequencies. It smooths. I keep it off for DVD reencodes.
The manual says the vertical filter reduces "speckle noise" whatever speckle noise is. I always thought that a vertical filter was a spatial filter. In any event, I don't knowingly apply spatial or temporal filters to my encodes, and keep it off.
Dithered quantization adds noise to the encode, which is the last thing I want. I keep mine off. It's supposed to help with "contouring artifacts", but since I've never seen any artifacts of that type, I have no interest in it. Any filtering I want to do, I do using AviSynth.
For encodes of material other than DVD stuff, I can see how you might need some of these. For DVD reencoding, where you want to keep as much of the original detail and sharpness as possible, even the default settings for these filters is too much, in my opinion. Others might tell you differently.
Read your manual. -
Thanks for the reply -
Just did a bit of digging on my sysytem - had not realised the manual was there with the trial version - It's a sunday - brain not fully engaged yet
3D Comb Filter and Pass Thru
By RidgeShark in forum DVD & Blu-ray RecordersReplies: 2Last Post: 14th Jun 2010, 23:36 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
ac3 filter settings questions
By THX-UltraII in forum AudioReplies: 0Last Post: 11th Feb 2009, 06:32 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 18:30
