I am using Nero to converse AVI into DVD and for whatever reason I am not able to get this done.
I have done everything..
Totally removed Nero with the cleaning tool
Both the writers I have removed and re-installed
I have checked with Gspot and Videoinspector for any hitches in the file
What more can I do?![]()
sorry for being human,
it appears NOT to be a common mistake -
It's hard to help without knowing the actual problem you are having.
My first suggestion would be to use a better tool...such as ConvetX2DVD. Nero is well known for having conversion issues...just check all the other "avi to dvd" conversion posts in this forum.Google is your Friend
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 13:25 -
C 1300 disc is dirty error on NEW blank dvd's
By rrtbusa in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd May 2010, 09:25 -
Hauppauge HVR-1300 and Virtualdub Cannot Capture
By JonnyAlpha in forum Capturing and VCRReplies: 5Last Post: 13th Feb 2010, 10:39 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 13:35
