I am converting old VHS tapes to DVD's. I plan to do some light editing (titles and some special effects) after the burn.
This may be a dumb question, but I should be burning to DVD+RW media and not DVD+R)? Is this correct?
I will probably be using PowerDirector or something similar for the editing. thanks
JaredKnight
DVD+RW has a 2.4 times higher basic writing speed than DVD-RW. You are better protected against shocks during writing, since the exact location can be found even during recording on DVD+RW. Like guns1inger stated you save money...
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
