I get this error message when I try to convert something in AutoGK.
I haven't seen the message before today, and I'm not aware of any changes to my system that would change my encoding capabilities.
I tried re-installing AutoGK, and I even tried doing a system restore, and I still get the message. It appears to give me this error whenever I try to convert something, regardless of what the source material is.
I tried a couple VOBs, and a couple AVIs. Same error.
Here's a little bit from the AutoGK log, if that helps
Any help would be greatly appreciated.[2/10/2007 11:36:17 PM] Output codec: DivX
[2/10/2007 11:36:17 PM] Audio 1: 128 Kbps CBR MP3 2ch
[2/10/2007 11:36:17 PM] Subtitles: none
[2/10/2007 11:36:17 PM] Format: AVI
[2/10/2007 11:36:17 PM] Target size: 20Mb
[2/10/2007 11:36:17 PM] Custom resolution settings: fixed width of 320 pixels
[2/10/2007 11:36:17 PM] Audio 1 settings: CBR MP3 with bitrate: 96Kbps
[2/10/2007 11:36:17 PM] Started encoding.
[2/10/2007 11:36:17 PM] Source resolution: 640x272
[2/10/2007 11:36:17 PM] Source fps: 23.976
[2/10/2007 11:36:17 PM] Output will contain 8798 frames
[2/10/2007 11:36:17 PM] Demuxing audio.
[2/10/2007 11:36:25 PM] Audio1 size: 5,870,523 bytes (5.60 Mb)
[2/10/2007 11:36:25 PM] Overhead: 322,944 bytes (0.31 Mb)
[2/10/2007 11:36:25 PM] Video size: 14,778,053 bytes (14.09 Mb)
[2/10/2007 11:36:25 PM] Target bitrate is: 322kbps
[2/10/2007 11:36:25 PM] Running compressibility test.
[2/10/2007 11:36:55 PM] Duration was: 29 seconds
[2/10/2007 11:36:55 PM] Speed was: 67.80 fps.
EXCEPTION: Open avi failed.
[2/10/2007 11:36:55 PM] Job finished. Total time: 38 seconds
asdf
UPDATE: I still have no clue what the problem was, but I figured out a solution. I went to the last video that I converted, checked the properties for the date it was converted, and did a System Restore for the day before. Now it works fine. I have no clue what caused the problem, but now the problem is resolved.
asdf -
Hi-
Lots of possible causes. Lots of possible solutions. The most common solution is to:
And if that doesn't fix it, then the next time it happens work your way through this thread, trying the various solutions proposed:run /autogk/vdubmod/aviproxy/proxyoff.reg file
http://forum.doom9.org/showthread.php?s=&threadid=76335
AutoGK Error Message
By WuPhilly in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2008, 19:12 -
Strange Error Message when trying to encode to DIVX
By Meiso in forum ffmpegX general discussionReplies: 1Last Post: 1st May 2008, 10:20 -
Strange AutoGK output files
By bennyboy371 in forum DVD RippingReplies: 7Last Post: 14th Mar 2008, 09:21 -
unsupported audio type error message in AutoGK
By ham2405 in forum AudioReplies: 2Last Post: 26th Dec 2007, 17:53 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
