  1. Ive been downloading Nerovision Express for a while now to encode downloaded movie files.I have a movie file that has very quiet audio. So i have messed with the audio filters and tried adjusting the audio but failed to get the volume any higher. So is is possible to turn the volume up with Nerovision?. If not can i import a wav that i have altered the volume?. I know i can rip the wav and turn the volume up with the likes of Virtualdub and Goldwave.
    Thanks for any help.
    Apr 2004
    Miskatonic U
    Why not just change the volume in virtualdub, then use Nerovision (if you must) to encode after than. I don't think NV likes elementary streams, and even if it did, I would not trust it to keep audio in sync.
    Read my blog here.
  3. I have altered the audio with virtualdub but cannot find a point to import the wav. It seems to just want to use the audio file form the original source unlike Mainconcept and Tmpgenc where you can specify the video and audio files.
    Apr 2004
    Miskatonic U
    Simplest is virtualdubmod for audio work. Streams-Stream List. Click add and import your new audio, then disable the old and save a new file in Direct Stream Copy mode.
    Read my blog here.
