I had a VHS transfered to a DVD. To make this post short, what i need to do is re-chapter the DVD while deleting some content from it, and swipe out the soundtrack.
It's some old 8mm home movies, so it's just music in the background that needs to be redone. So, ideally i'd love be able to just import the existing DVD's, create an MP3 playlist, and create the DVD with menus and chapters. Is there one tool out there can help me do all this? Or am i stuck editing the audio in another app? I've been trying to find for a few days now, and i am stuck
Thanks!
Tmpgenc DVD Author should be able to do all of this, however you would have to work out exactly where your cuts would be, and how long the new audio track is to you can create it and import it separately, or you can make the cuts, save the project and author, then demux the audio from the resulting DVD, edit and change it, then open the original project and replace the old audio with the new.
Read my blog here.
well, that's what i was hoping to avoid. figuring out where the cuts would have to be is much more work then just doing the whole video in the extranal
*sight* back to searching.... -
Your problem is you have two separate jobs, and you want one tool to do them both. You should ideally do your editing and changes to the audio in an editing package, then author in an authoring package.
Simplest method : VOB2MPG to extract your video from the current DVD, Womble Mpeg Wizard to add the audio and make the cuts, which will also stop you having to re-encode all the video, then re-author in TDA to create new menus and add chapters.Read my blog here.
thank you very much, this is what i was looking for
while it would be nice to just have one tool, i guess i am asking too much.
I am half way done getting the video though MEG Wizard. The app is pretty nice, despite having a terrible interface.
Is there a tool to extract chapter data and timecodes from m4v files?
By ihudson in forum EditingReplies: 3Last Post: 27th Oct 2012, 13:17 -
Could we use the DVDremake tool to remove DVD Chapter Marks?
By jjulio1 in forum DVD RippingReplies: 1Last Post: 5th Aug 2010, 10:41 -
How To Change Chapter Numbers
By vomiranda in forum Authoring (DVD)Replies: 1Last Post: 5th Jul 2010, 12:46 -
How can i change soundtrack ?
By forcedv in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2009, 10:48 -
Chapter Tool?
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2007, 10:55
