I know how to do the silhouettes for pictures or art. Can someone please explain how it is done with video. I am currently using adobe premiere
How's My English?
There are two simple ways.
1. Have the backlit subject darkly dressed in front of a bright, well lit background, then use contrast filters or the difference matte to separate and mask the subject
2. Similar to the first suggestion, however put them in front of a blue or green screen so you can use keylight or similar to get a good quality mask.Read my blog here.
thanks.
Tell me something. If i had created the video already without these in mind. How would i be able to create the silhouettes with premiere.How's My English? -
You could try the difference matte. Otherwise, you would have to use something like After Effects or Combustion that would allow you to rotoscope your mattes by hand using splines. Time consuming stuff.
You might want to have a read of this first : https://forum.videohelp.com/viewtopic.php?t=321490Read my blog here.
Create a video from several pictures
By snewt in forum ProgrammingReplies: 1Last Post: 29th May 2011, 18:45 -
Create Anaglyph 3D Video
By Tugan in forum Video ConversionReplies: 11Last Post: 10th Jan 2011, 22:28 -
Video editing programs letting you create .m2ts files with VC-1 video?
By justin0324 in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Mar 2009, 22:24 -
How Did They Create This Video Effect?
By Soopafresh in forum Newbie / General discussionsReplies: 5Last Post: 28th Jul 2008, 11:34 -
possible to create video with a clone of me?
By jh1017 in forum EditingReplies: 2Last Post: 6th Nov 2007, 00:03
