Does anyone know where to find good test patterns. I want to use them to determine when in the process audio out of sync conditions are being intoduced. It is sometimes difficult to tell if the dialog is out of sync with the video.
If you have a camcorder, record some "slapstick" shots and transfer them to the PC in AVI format. That should work good as a audio/video sync test file.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 02:15 -
870118 - finding similar patterns
By hamidi2 in forum AudioReplies: 0Last Post: 6th Apr 2008, 09:49
