Is it worth buying the XBox 360 HD DVD player?
I use my HDTV as my PC monitor. Will viewing DVD's via my PC give as good quality as the HD DVD player for the XBox?
if you have an hd video card, and are using the proper hd connections, yes
I am just a worthless liar,
I am just an imbecil -
You will also need the hack drivers for the external HD-DVD drive for that Windows can use the drive.
You'll also need software to view the Movie.For the love of God, use hub/core labels on your Recordable Discs! -
But can it go out 1080p? I know it can't with the the 360 because of no hdmi. But can you do it the hacked pc way to 1080p? If not then you'd be better off buying a full fledged standalone hddvd player for full output.
Is there a dvd player that you can select ycbcr601 other then the Xbox 360
By Evil Monkey in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Jun 2009, 09:44 -
Xbox 360 HD-DVD Player on PC
By WiReTaP in forum User guidesReplies: 48Last Post: 26th Dec 2008, 13:35 -
XBOX 360 HD-DVD Player problem
By maldb in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Dec 2007, 20:25 -
Using the XBOX 360 HD DVD player on a PC
By the_importer in forum Media Center PC / MediaCentersReplies: 4Last Post: 12th Nov 2007, 21:39 -
By Tchail in forum Software PlayingReplies: 6Last Post: 10th Oct 2007, 15:07
