I use "Particle Illusions" for making different particles but I have problem when I want to export and save the produced AVI clips. For example, I can't export the clip as RGB 32 bit AVI file that I can use as overlay clip in Vegas for instance, but Particle export only as RGB 24 bit AVI clips which I can't use because I can't produce overlay effect. Maybe someone has more expirience using this program .
Regards.
QUALITY HAS A NAME
Putting Particle Emitter Behind a Person in Motion - Is it Possible?
By ofpeb in forum MacReplies: 1Last Post: 2nd Mar 2012, 11:36 -
Particle Illusion - Import and export HD material - Tutorial
By Ariel García in forum EditingReplies: 0Last Post: 30th Apr 2011, 18:14 -
Help Help Help! Premiere AgedFilm Export problem!
By qisheng in forum EditingReplies: 0Last Post: 26th Dec 2009, 12:03 -
Premiere Pro CS3 EXPORT PROBLEM...
By REiGN in forum EditingReplies: 2Last Post: 25th Feb 2008, 18:30 -
Subtitle export problem
By s_a_m4000 in forum SubtitleReplies: 3Last Post: 2nd Nov 2007, 06:55
