Hi,
I have rmvb files i need to convert to xvid (208x176). I have Xvid Codec, FFdshow, Real Alternative, and virtual dub installed. I also have smart movie installed and it converts the rmvb files too but the problem is the audio video sync..
I read some tutorials over here how to open rmvb with virtualdub and i succeeded in converting the files with reduced frames and they worked perfectly on my mobile.![]()
Now the problem is i want to use mono for audio. I tried doing it via Audio > Conversion (in virtual dub) to 22050 hz and mono channel but while saving file it gave error.
Plus in Audio > Compression menu i am using MPEG 3 32Kbps, 22050hz..
Now is there a way i can change the audio to 40 kbps 22050 mono ??
Secondly when i convert videos using the xvid codec i installed at 128 kbps, 11.98 fps and 40 kbps mp3 mono i get a file size of 14 MB but when i convert it via virtual dub i get a filesize of 24 MB.
In virtualdub i am using 128kpbs xvid, 32 22050 hz mono and 11.98 fps ..
I am new to conversion please help...
Thanks a lot.
Results 1 to 1 of 1
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Conversion Help
By slayer_of_all in forum Newbie / General discussionsReplies: 2Last Post: 8th Apr 2010, 09:45 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
.TS or .TP conversion
By joepic in forum DVB / IPTVReplies: 4Last Post: 22nd Jan 2009, 13:22 -
2.35:1 conversion to 1.85:1 (or 1.77:1)
By mgarrido in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2007, 23:21
