Hi,
Can anyone recommend a freeware JPEC compressor ? Thanks.
Results 1 to 10 of 10
Do you mean an image editing program or a JPEG codec for video ala PICVideo MJPEG (which is probably the "best" one but not freeware)?
Hi John,
Sorry. I am refering to software to make JPEC picture file from my digital still camera small. I need to email the digital photo to my friends via email. -
One tool I'd recommend would be IrfanView. It's primarily for viewing images, but can also do a number of operations on those images, including changing the compression on JPEGs (cropping, rescaling, lowering the color count may also help).
If cameras add ten pounds, why would people want to eat them? -
I think what you really mean is an: "Image Optimizer".
Useful for when you have an decent sized image with a needlessly LARGE filesize, like 2MBs. And once optimized it becomes a reasonable 60k.
I came across this on a google search, looks good and free:
http://tools.dynamicdrive.com/imageoptimizer/ -
I use the Image Resizer, one of the Microsoft Powertoys. You can find it here. It is free and it works - not bad for a M$ product... the link to download it is to the right on the page, you will need to scroll down a bit.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Even the crappy little Paint program that ships with Windows can resize images and save as JPEG.
Here's one I use that is free
http://www.vso-software.fr/products/image_resizer/image_resizer.php -
Folks, Thanks again.
I ended up using Visualizer Photo Resize (freeware) from
http://www.snapfiles.com/Freeware/gmm/fwgcomp.html.
No particular reason for selecting it.....
What is the best compressor to use???
By BobAchgill in forum EditingReplies: 7Last Post: 13th Sep 2011, 06:55 -
HDV7 compressor is ..... ?
By ermetekos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 3rd Nov 2009, 14:00 -
Compressor Needed
By mytabbycat in forum MacReplies: 4Last Post: 3rd Nov 2007, 05:54 -
regarding VP video compressor
By liddu in forum Newbie / General discussionsReplies: 6Last Post: 14th Jul 2007, 08:15 -
Why is compressor lying to me??
By whiff79 in forum MacReplies: 2Last Post: 4th Jun 2007, 14:38
