Hello, my son is interested in 3D animation and I thought I would start him on an older copy of Lightwave. A older version 5 is great because he just needs the basics to start. Plus the upgrade is probably over a grand.
Although version 5 works the build avi plugins seem to break under XP.
Basically my question is:
Is there a good freeware or shareware package that will build anims out of sequences of frames?
Thank you for your time.
VirtualDub
Just load the 1st jpg file, and it will automatically load the rest.
merge multiple avi to 1 single file
By carlos28355 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Oct 2010, 19:11 -
Convert VIDEO_TS folder into a SINGLE AVI file
By donkeyking in forum Newbie / General discussionsReplies: 6Last Post: 29th Apr 2010, 15:32 -
dvd to a single avi file
By makapa in forum DVD RippingReplies: 1Last Post: 30th Oct 2008, 11:40 -
How to combine 2 avi's one above one below into a single file
By werx in forum EditingReplies: 2Last Post: 5th Oct 2007, 07:53 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
