I need(new or used) two 512mb rimm4200 memory modules. I have looked in all the usual places and it seems that no one has any. Ebay has some 256mb modules but I need the 512mb modules. If anybody has any lying around and would like to get rid of it please contact me: mysts@northstate.net or post here. thank you
Looks like they have some here:
http://www.mysimon.com/9000-11564_8-0.html?sdcq=dnatrs-512_mb/dfllTrail-512%20MB/keyword-rimm%204200 -
Those aren't RIMMS. If he is in fact looking for RIMMS (Rambus Inline Memory Modules), I don't think they have anything near 4200, if you're looking for DDR2 PC2-4200 512MB SDRAM modules, here are some...
http://www.newegg.com/Product/Product.asp?Item=N82E16820134081 No guarantee of compatibility since they're buffered though.Nothing can stop me now, 'cause I don't care anymore. -
Thanks for the help guys. I didn't think to mention that the form factor is 184 pins. That has been the problem. All that I have found are 200 pins and above. Thanks for trying though.
crucial one of the best memory makers
http://www.crucial.com/store/listmfgr.asp?cat=RAM
use Crucial Memory Advisor Tool to find the right memory for your PC -
184 Pins would be DDR or RDRAM. Where are you seeing that you need 4200?
The manual that came with the motherboard kept referring to RIMM 4200. I contacted the people that sold me the motherboard and they said that this memory is no longer available. I contacted Crucial and they do have it. You are correct in saying that 184 pin means RDRAM(rambus). Everything is OK now and I appreciate your efforts to help.
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
AMD X2 4200 Shutdowns
By kenmo in forum ComputerReplies: 16Last Post: 25th Mar 2009, 08:43 -
Can I mix PC 4200 AND PC 4300 DDR2 RAM?
By julitomg in forum ComputerReplies: 4Last Post: 1st Jan 2009, 20:15 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
