I have an odd one. I have an iso file for a PC App that I burned to cd via Nero. Burned as a disc image, which put it over with all the necessary setup files on the cd. Problem is, when I try to run the setup.exe (or any other exe), it does nothing.
I can browse sub-folders on the cd and things that would be installed in the application, such as small audio/video files, work fine. Just can't run the dang setup to get the full installation.
Any clues???
Download Daemon tools http://www.daemon-tools.cc/dtcc/download.php?mode=ViewCategory&catid=5 and mount the iso image (the one on ur hdd not the one you burned) onto the daemon tools virtual drive and see if you can run the .exe file from there .... if not i suspect it is corrupted ... if it will run then there may be a problem with the burn proccess when you burn the iso to disk
Outstanding. Wish I would have found this forum a long time ago. What a great answer! I have tried other ISO products and their demo versions (most asked for some high payment for their product) sucked and did nothing. This product was quick, easy and worked like a charm. Thanks for the tip!
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
ISO help
By Jacks_Daddy07 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2009, 16:19 -
ISO
By shapper in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2008, 10:31 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
ISO
By bogb in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 12:08
