the error i get is..
I saw the video running in aVid..so i know theyre not broken.. i took the externalDrive with me home.. and only one file opens.. the rest does not..Code:After Effects: AEGP Plugin OMF: OMF file is not a video OMFI ( 5027 :: 12 )
Am i missing out on something?
note (im using adobeAfterEffects 7 pro)
Try renaming the files to raw .dv extension.
They should open in After Effects then.
BTW, in order to change the file extension, you have to make sure you have "Hide files extensions for known files types" in windows explorer turned off. -
thanks.. i never tried if it worked tho.. the avid guy is going to export to a "normal" video output..thanks for your solution tho.. ill try it next time ill run into that problem.
(i bet someone else will find this post useful anyways) -
Be sure he's exporting it to a non-propriety Avid format (Lossless Quicktime or AVI). Because, if he does, you still might not be able to open them.
If that's the case, then you'd need the codecs. They are freely available on Avid's site.
http://www.avid.com/onlineSupport/supportcontent.asp?productID=0&contentID=7952
Cant open certain web pages & photos dont appear, just boxs + red crosses??
By jacknscoob in forum Off topicReplies: 1Last Post: 7th Feb 2012, 12:03 -
After Effects - comparable open-source or lower priced?
By magic612 in forum EditingReplies: 7Last Post: 15th Sep 2011, 13:15 -
Importing .mp4 files into Avid MC 5
By barrylay in forum Video ConversionReplies: 9Last Post: 12th Mar 2011, 20:19 -
I dont understand .mkv files at all!
By InfernoParadox in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 00:21 -
AVID MXF Files won't open!
By M3G4 in forum Video ConversionReplies: 3Last Post: 14th Oct 2010, 09:01
