Hi everyone, first time here...
I got this problem: I extracted the vob content from an already authored DVD for re-authoring it. I used VobEdit for this, turning the vob files into a single .m2v file. The problem is: when I try to import the .m2v file into Adobe Encore, it says the file needs to be re-transcoded. Why? Shouldn't Encore just open the .m2v file, without re-transcoding it once again? Thanks!
Hey Baldrick, thanks for the welcome and for this mediainfo. Great tool I didn't know!
Here's the .m2v info:
Format : MPEG-2 Video
Format/Family : MPEG-2
File size : 3.54 GiB
PlayTime : 1h 31mn
Bit rate : 5509 Kbps
Video #0
Codec : MPEG-2 Video
Codec profile : Main@Main
Codec settings/Matri : Custom
PlayTime : 1h 31mn
Bit rate : 9800 Kbps
Bit rate mode : CBR
Width : 720 pixels
Height : 480 pixels
Aspect ratio : 4/3
Frame rate : 29.970 fps
Standard : NTSC
Chroma : 4:2:0
Interlacement : Top Field First
Bits/(Pixel*Frame) : 0.946
Guess it should be alright, shouldn't it?
end of file--Adobe Encore
By koberulz in forum Authoring (DVD)Replies: 19Last Post: 18th Oct 2016, 20:21 -
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 06:30 -
Adobe Encore CS4: How to reduce output file size?
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 8th May 2010, 12:19 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 00:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 16:03
