my laptop has a toshiba SD-R6112 dvd-rw drive which reads software and original dvd's ok but dont seen to read backed up dvd's and dvd's from abroad.
anyway to get round this?
If you open windows explorer or my computer with the disc in the drive, can you see the contents?
Google is your Friend -
no, its like nothing is inserted. when I click it it says please insert insert a diskOriginally Posted by Krispy Kritter
That's a tough one. My first thought was the region code. But if you insert a disc from the wrong region, the disc should be readable, however, when you try to play it you will get a "incorrect region" message or something similar.
Also, from the specs it appears to only support -R discs, so if your "backed up" discs aren't -R, that could be the problem.Google is your Friend
how do i copy DVDRAM disks to a pc hard drive (retaining exact quality)
By mnbvc in forum DVD RippingReplies: 19Last Post: 23rd Sep 2015, 15:18 -
LG GSA-4160 stopped reading DVD-RAM disks.
By lennyt in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2008, 14:56 -
DVD drive stopped reading DVDs for a very random reason..
By narutoball in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Oct 2008, 16:23 -
GoldStar GSA-4160B stopped reading DVD-Ram disks
By lennyt in forum DVD & Blu-ray WritersReplies: 3Last Post: 2nd Jan 2008, 12:12 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
