I have a few footy games recorded and their all around 7gig or so each with about a 3hr duration. These are the specs:
Summary:
Bit rate: 6440kbps
Video:
Format: mpeg2video
Frame rate: 25.00fps
Audio:
Format: mp2
Bit rate: 224kbps
Sample rate: 48000Hz
Channels: Stereo
How should i convert them to smaller files without loosing noticable quality. i have used Xilsoft and converted them to divx, xvid, etc but even at 2000+ bitrate they are pixelated and still pretty big. I recorded them on a Winfast tv2000xp tuner card and i have recently changed the capture profile codec from mpeg2 to ffdshow encoder and the size(9mb per min)/quality ratio is near perfect. is it possible to convert the large mpeg2 video using ffdshow codec??
I don't see why not, you could get a program like vitrual dub mpeg2 or mod and throw you video in ther, set the video and audio to full processing and change the codec settings to exactly what you recrod now. There might be a litte different depending on the soruce materiel but it should be too bad. Just make sure your settings match what you record as now.
Converting video to MPEG2 for Sony Bravia TV
By Teufelshunde in forum Video ConversionReplies: 7Last Post: 6th Jan 2011, 10:39 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Converting or Muxing audio files (mp3 etc.) into MPEG2 TS without any video
By kary.sharma in forum AudioReplies: 1Last Post: 5th Dec 2008, 09:43 -
By kary.sharma in forum Video ConversionReplies: 1Last Post: 5th Dec 2008, 08:07
