sometimes after converting avi files to dvd the opening will repeat itself i usually burn at 8x most of the time any suggestions? doesnt happen everytime but happens more than it should
More info' is needed. Which tools did you use to convert?
He's a liar and a murderer, and I say that with all due respect. -
ive used avi2dvd
thefilmmachine
convertxtodvd
and dvd flick
avi2dvd and thefilmachine seem to be the worst but has happened with
the other programs as well -
ive used
memorex 16x dvd-r's they seem to be the best but ive had 5 or 6 that the first chapter on the disc loops if ff then rewind it seems ok but then others come out just fine i usually check the avi files for errors b4 converting -
ive also used sony maxell & tdk media and have the same problem with some but not all i just dont like having to ff then rewind to make the looping stop ive also tried several different players as well im on my third player a durabrand dvd1002
playback problem
By winston879 in forum Software PlayingReplies: 2Last Post: 14th Mar 2011, 15:33 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Color Playback Problem?
By magikalfly in forum Video ConversionReplies: 7Last Post: 19th Feb 2009, 00:14 -
AAC 5.1 playback problem
By TigerShark in forum AudioReplies: 0Last Post: 30th Sep 2007, 11:08 -
playback problem
By stigslim in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Aug 2007, 18:19
