Currently I have a couple of VCDs and it seem that there are 2 languages. Korean on the left channel and Chinese on the right channel.
I was wondering if there is a way to rip the right channel and then encode it back into the video into both Left and Right channel chinese.
I had tried ripping the right channel only and encode it back to the video but when playback I only get right channel to have sound and left channel is mute.
When playing the VCD on a DVD player, just clicking the "Audio" control on the remote, which changes audio tracks on a DVD, should switch from stereo (both languages at once) to mono-left, mono-right; this has worked on every player I've used anyway.
But if you're going to rip it anyway, you can put several VCDs onto one DVD. At least you don't have to switch discs in the middle of a movie.
See SVCD2DVDMPG for one way to do this. -
Originally Posted by AlanHK
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 04:35 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47
