Okay i use psp video 9 for ipod not psp. The problem was back then my psp video 9 was great idk what i did, and my ipod video would basically play the movies on "super widescreen". The blackbars were basically removed, there was about a cm of black bars, so the widescreeen was big..using most of the ipods screen. I had to reformat my pc and now my new psp video 9 settings convert movies into a widescreen that use so little of the screen...there is huge black bars and most of the screen isn't being used...What do i do and i can't use custom resolution?? Please help and thank you. here are some pictures of the comparison..
THIS IS WHAT I DON'T WANT BUT HAVE ON MY NEWER MOVIES
This Is MY Old Videos
Results 1 to 9 of 9
Your source material dictates your output. Your issue is no different than the "black bars" that appear on your TV during various widescreen movies. The original aspect ratio changes the "size" of the black bars. Your only choice is to stretch the image to make it fill the screen or crop the edges to make it fill the screen.
Google is your Friend -
So one it depends on the movie correct? What can i use to crop the edges..i use Pspvideo 9, and it did it for me with my old movies..Originally Posted by Krispy Kritter
Let me understand you correctly ... you want to cut of the edges of the picture so you can make it bigger?Originally Posted by heartbreaker
Is this really what you are saying? If so think about the implications of it ... you will not be seeing the entire picture!
okay what i want is really a "taller Widescreen", the widescreen is too small to watch, and the fullscreen cuts out a lot of the picture...i have asked this same question on 4 different forums and tried every profile on pspvideo9...please help. Thank you for the quick response.Originally Posted by FulciLives
Since the psp uses a 4:3 screen, what you are needing to do is crop the left/right sides of the video. There is no other way of making the video "taller" without distorting the picture.
I use an ipod video XD...what is the psp's naive screen resolution?Originally Posted by Krispy Kritter
From the Ipod website:
Display
2.5-inch (diagonal) QVGA transflective, over 65,000-color liquid crystal display with white LED backlight
320 by 240 pixel resolution, .156-mm dot pitchGoogle is your Friend
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 8Last Post: 10th Jan 2026, 15:42 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 09:12 -
Video Motion and Cropping YouTube Videos
By Deter in forum Video Streaming DownloadingReplies: 0Last Post: 20th Dec 2009, 13:36 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 23:13 -
Cropping Videos
By camp in forum Newbie / General discussionsReplies: 29Last Post: 24th Nov 2008, 13:42
