So the problem is audio on my burned dvds.
The video is fine for what it is.
I have "cracking" during I suppose the higher range sounds of the audio.
Google video is the worst with this problem.
I use Any Video Converter v1.21 to go flv to mpg.
(the default option for NTSC dvds:
audio codenc - ac3
audio bitrate - 128
audio sample rate - 48000
audio channel - 2)
It says .mpg but some programs(Nero) view it as .avi - I don't know......
Then I use Nero Vision Express 3 to burn
When checking for this problem before the burn (on the .mpg) my video players do not have this problem, but when I use Nero and near the end of the wizard there is a video player to test what the final dvd will play like. The audio problem is present on the Nero player.
I do have the older versions of Any Video Converter which supposedly allow changes in the audio bitrate and have tried up to 400. same problem.
Is this just a volume issue?
The DVD volume level is sounds normal on the TV.
I am open to better software if you peeps are doing flv to dvds and are not having audio issues.
Any help is appreciated.
*Wasn't sure if this was for the Conversion board or the Audio board. Please move it accordingly for me. But I am a newbie so you can leave it here too :P
Results 1 to 12 of 12
Basically, Nero sucks for video conversion. Sometimes it works and sometimes it doesn't. Your best bet is to find a different better conversion tool. The most popular tool at the moment seems to be ConvertX2dvd. Or get a dvd player that will play avi and raw mpeg files and save time converting and use fewer dvd's.
Google is your Friend -
Thanks for the reply.
Any advice for fixing Nero?
convertx2dvd is a burning program? I clicked the link but don't really understand what it does other than convert. Should I use this to convert then use Nero to burn? -
The link tells you what it can do.....It converts your single files into a compliant DVD Video set of files and burns it on a DVD media. Supports switchable subtitles from srt,sub/idx.
Another option is to use FLVextract http://www.moitah.net/download/latest/FLV_Extract.zip
It will demux the audio and video from the flv file. The audio is mp3, so you can open it up in Audacity and clean it up, saving the file to Stereo WAV format
I agree, ConvertXtoDVD is great -
So is my problem Nero or Any Video Converter?
I actually tried using AVC to convert an AVI to AVC's DVD format. (I know unnecessary but just tried it)
And I got the same problem.
Someone on here has got to be using the same combo as I am.
Please point me to some good freeware!!! -
@Soopafresh
Do I use FLVextract then Audacity then Nero?
Well, I'll go and try and report back.
Hope it's all freeware.
Thanks. -
Yes, all freeware. But I do agree that ConvertXtoDVD would work best. Worth a few $ for the ease of use.
But with FLVs, you can always just demux the audio anyway with FLV Extract.Originally Posted by Bjs
If cameras add ten pounds, why would people want to eat them? -
Here you go, this batch file will create a 2 track 48000hz normalized WAV file from your flv, which means that you can use it as the audio track for your DVD encode.
The only rule:
The flv name can't have spaces in it:
Bad: My File.flv
Good: My_File.flv
The WAV will be named OriginalFile.flv.WAV
Instructions:
Download and unzip to its own folder.
http://www.bestsharing.com/files/aeohwrl225497/FLV_Audio.zip.html
Place your flv files into the same folder
Double Click on FLV_Audio.bat
Afterwards, you can still load the resulting WAV into Audacity if you want to EQ the sound further, but this automatic method doesn't sound bad at all.
If you want to convert the entire flv into an "uncompressed" AVI file (actually Huffyuv) for fast Mpeg2 encoding, let me know - it's an easy fix to the batch file. However, It needs tons of temporary disk space if you decide to go that route -
10GB for every hour of flv -
Thanks for the replies!
Well, I went a different route. Mostly because I didn't want to spend any money just to get FLVs on my TV.
I used Super to convert into DIVX. I went with all defaults and then clicked the normal DIVX format (all divx players).
Cracking audio problem is now gone.
The problem was Any Video Converter's audio converter I guess.
Anyway, problem solved.
Any other tips would be welcome.
Cutting a flv in Virtualdub - audio synch problems
By Faufiffon in forum Video ConversionReplies: 3Last Post: 1st Sep 2011, 15:49 -
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 13:39 -
Audio out of sync when ripping DVD to hq flv
By SystemlordAnubis in forum DVD RippingReplies: 0Last Post: 12th Jan 2011, 07:13 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 12:51 -
FLV to DVD - audio out of sync
By intel352 in forum Video ConversionReplies: 16Last Post: 30th Mar 2009, 15:07
