Results 1 to 9 of 9
  1. Hi
    I try to convert a mpg1 file into mpg2 using tmpgenc
    the source file is about 1 hour long and it play fine for the full hour using windows player classic
    After converting the file if I look at the result output file, it freeze at about 15 minutes of the beginning the same frame is stuck there until 2 minutes before the end of the movie ???
    Can anyone have any idea why this this is happening and how can solve this issue ?
    thanx
  2. Member Soopafresh's Avatar
    Jan 2004
    Could be a number of things. You'll have to try one thing at a time to figure it out.
    1) Bad source file
    2) Bad resulting file
    3) Bad Mpeg2 Player
    4) File size limitation
    Try demuxing and remuxing the mpeg2 audio and video in TMPGenc. If that doesn't work, try demux-remux (under Mpeg tools in Tmpgenc) of the MPEG1 file, then try encoding THAT file.
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    If you're doing this because you want to author to DVD, consider just demuxing and resampling the audio to 48k. MPEG1 video works fine on a DVD if your authoring program isn't too stiffnecked to accept it.
  4. Ok I try to demux the original video file it worked
    but now when I try to open the audio mp2 file to remux it I have this error
    Illegal MPEG audiostream
    any idea ?
    Jan 2007
    me I would to a file copy on the orginal, then open that and edit out the frame where the movie hangs, then let tempgenc or another program do the encode
    in other words remove the spot that is currupting the final product
    BUT thats just my point of view, one frame out of 30 for that second sure isn't going to be missed when you play the movie
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    any idea ?
    Error from what?
    Did you resample the original audio?
    VCD MPEGs have audio sampled at 44k, DVD needs 48k.
  7. What tool do you recommand to remove the freezing frame from the movie ?
    No I did not try yet to resample the audio , do you think my problem is an audio problem, i tought it was one with the video from the original file ...
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Well, you did say "illegal audiostream".
    MPEG1 video is fine for DVDs, but the audio has to be resampled.
    Was the error from an authoring app? Or what?
  9. This error happen when I try to open the audio after demux to remux it with tmpgenc
    I will try to resample the audio
