    Feb 2007
    I love RipIt4Me program--can anyone explain what is taking place when I use it?
    I know it uses DVDDecrypter, then Shrink, but how does it create the files to burn with ImgBurn? I have an 8.5G file after I ran it through shrink, and would like to use the same features that are set up in RipIt4Me to create a double-layer file to burn with ImgBurn.
    RipIt4Me seems only to work from a DVD and not from Shrink files. I have Nero Express but have had bad luck with it in the past trying to create dual-layer iso files. If RipIt4Me uses Nero, does anyone know what settings it is using?
    I had been creating ISO files using an earlier version of ImageCopy, but not so goodf for double-layer creation. RipIt4Me has given me great results including the layer breaks. Any help would be appreciated.
  2. Member jeanl's Avatar
    Sep 2004
    CA, USA
    Burn your ISO with ImgBurn... It's excellent for DL ISOs. RipIt4me can't help you there. Use ImgBurn directly.
    Jeanl
    MenuShrink a free tool to shrink menus into stills with or without audio!
    DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
    Feb 2007
    I was trying to use ImgBurn to create the ISO but was unable to open the Shrink files. I tried the different modes, but the folder showed up blank where the Shrink files are.
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    edit
    There's no need to use DVDSHRINK if you're going to burn DL media.
    Read the RIPIT4ME guide:
    http://www.ripit4me.org/guide.html#wiz1
