Do you think the authors will ever address the problem DVD-lab PRO 2 has of crashing everytime you ask it to deal with a compilation containing multiple VTS?
I'm just sick of having to have both v1.60 & v2.xx installed just for when I need to author a disc with multiple VTS.
Results 1 to 10 of 10
What type of problem are you having? I've used multiple-VTS's a few times without any problems...
btw, there's a new update posted today -- v2.25
Regards,
George -
Just quite simply that whenever I go to compile a multiple VTS compilation, the compiler just crashes and exits early with no warning dialog, no error messages, nothing. It just exits as if it had finished but the files it creates can't be played and obviously aren't complete. v1.60 works fine. I'm talking about v2.25.
Can you post a Report of your project?
Also, what are your Virtual memory settings? Are you compiling to a separate hard drive?
Regards,
George -
Originally Posted by guns1inger
Are you compiling to a separate hard drive? -
Finally it would appear the v2.26 of DVD-lab PRO is the first version of the v2.xx stream to be able to compile multiple VTS structures correctly. Perhaps it was my tirade of abuse at them that finally made them look into it. Is it just me, or does v2.26 report being v2.25 in Help | About?
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
359 $ to handle XDCAM with Premiere Pro CS4
By Turmap in forum EditingReplies: 80Last Post: 25th Sep 2009, 14:16 -
Multiple episodes in one vts
By c9806961 in forum DVD RippingReplies: 12Last Post: 15th Aug 2009, 02:35 -
DVDauthor -- Multiple VTS from CLI
By VirtualDoobMon in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2008, 16:10 -
How to make xvid of VTS with multiple pgcs?
By Talayero in forum DVD RippingReplies: 0Last Post: 30th May 2007, 09:55
