    Feb 2007
    Germany
    Ok, first of all, hi everybody, ive been looking for this info for ages, and found nothing...
    My question is this; i got myself this 700mb movie .avi encoded with DivX, and well, it doesn't have the best resolution i have ever seen in my life...
    Is there anyway to raise it?
    Will be really thankful if someone help me out with this one
    Vielen dank...
    Garbage In Garbage Out.
  3. Member Soopafresh's Avatar
    Jan 2004
    Unless you want to learn Avisynth, unlikely.
    Dec 2003
    Heres a VirtualDubMod filter list I used recently on a similar project (divx-dvd). I exported the file from VirtualDubMod using Huffyuv codec (lossless) then encoded that to DVD using Tmpgenc. Results were ok.
    You should do a test clip before tackling the entire file. My system was only getting about 3-4 fps with these filters. Mighty slow process...
    Good luck.
