hi i have an ati 64ddr radeon and a soundblaster live value and when i capture i get a choppy sound i don't think it's my sound card cause while i'm capturing the sound is perfect it's when i play it back that there's a probleme... anybody got a clue?
thx
If you have a VIA chipset, it may cause some problems with the SBLive and IDE while capturing.
If so, you can try installing the via pci latency patch [www.viahardware.com]. Also, disabling UDMA (using DMA33 instead of DMA66) sometimes fixes the problem.
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 12:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 17:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 03:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 20:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 22nd May 2007, 23:44
