I have been testing out a Hauppuage card.
I installed all of the software related to the card.
I started off using WinTv2000 to capture vhs tape.
I was going through the different setting to determine which were support by the card.
I was able to go through all of the setting and capture a file.
Then I tried the Amcap program that was inititally installed with the capture card. I tried to run it but it hung up and would not respond.
It seem since this happen I can not use the WinTv2000 to capture anything.
If I start a capture it gives me the following error:
Stream Dshow error
RunGraph: Run () failed the system can not find the path specifed
(0x8007003)
I have tried to search for a solution or explaination to this problem but I have come up empty.
Do you need more information? Can you help?
Results 1 to 1 of 1
SeeYa
Never Say Never (Romeo Void 1981)
Firefox, Thunderbird
(DShow) filter Dump, cant connected to him input pin
By pror0ck in forum ProgrammingReplies: 0Last Post: 24th Sep 2011, 02:47 -
Stream DShow Error Messages on WinTV 1600
By SufferingHere in forum Capturing and VCRReplies: 0Last Post: 1st Aug 2009, 16:00 -
By alippman80 in forum Capturing and VCRReplies: 3Last Post: 26th Oct 2008, 12:12 -
using videos starts dshow over and over
By radman202 in forum Newbie / General discussionsReplies: 5Last Post: 29th Jan 2008, 11:49 -
multiple instances of dshow being activated
By radman202 in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2008, 10:50
