Hi,
Am new here so please be gentle. I've recently bought a Creative Vision M, and am using SimpleDIVX to convert DVD's to Avi files. 4:3 material works fine, bu am having problems with 16:9 material.
When I select the PAL 16:9 option in SimpleDIVX the resulting Avi file plays fine on the PC (i.e. in a 16:9 shaped window). However, when then transfer this to the Creative it plays in 4:3 mode and everything is streched vertically. I've checked the Creative's settings and there is no way to force it into 16:9 mode.
I guess what I need to do, is to create a 4:3 letterbox Avi file from the 16:9 encoded DVD, so that when it is played on the Creative, I will get the black bars, which is what I want.
At the moment I'm having to crop everything from 16:9 to 4:3 which has mixed results.
Any help would be greatly appreciated - for instance are there any other free software packages I could use.
SimpleDivX, and cropping/resizing
By snafubaby in forum DVD RippingReplies: 2Last Post: 21st Dec 2008, 16:39 -
Is SimpleDivx (Mencoder) multithreaded)...which encoders are?
By radium02 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 02:28 -
Does SimpleDivX install its own versions of codecs?
By Toastie in forum DVD RippingReplies: 0Last Post: 1st Sep 2007, 15:23 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57 -
SimpleDivX replacement
By alan79 in forum DVD RippingReplies: 3Last Post: 18th May 2007, 11:34
