Hi,
I recently converted using CCE a pal short film because I wanted to add it as an extra to a ntsc dvd.
The conversion was OK but I'm wondering if I trimmed a bit of the image, because of a wrong avisynth script.
This is the script I used:
Loadplugin ("d:\dgdecode.dll")
mpeg2source ("short.d2v")
lanczosresize (720,480)
converttoyuy2 (interlaced=true)
I thought that with this script I would preserved the totality of the image but now I think a bit is missing, I'm not sure.
Thanks in advance.
Nothings been trimmed out in the script. It's all there. If it seems to be missing image from around the edges when watching on television, then it's your TV set's overscan doing it.
I don't know your CCE settings, but I suppose there's a chance you have it set up wrong and it's doing something. When you play the resulting MPV on the computer, is it all there?
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 13:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 09:06 -
Converting homemade PAL to NTSC
By Kernos in forum MacReplies: 12Last Post: 18th Jan 2008, 15:48 -
Quick question - PAL Menu when converting NTSC Xvid
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Oct 2007, 11:46
