Most of the time when I dl movies in two parts, I joint them with “easy video joiner” and than burn dvd, with Nero or Ulead movie factory.
But some time, Nero and Ulead wouldn’t able do burn, as they held that data is huge to burn on the dvd. But its only 1.7 gb, and dvd is 4.35 gb.
How is this possible, where some movies easily burn and other are not?
Looking for help from you.
bobybell
You obviously have no understanding of what happens when you create a DVD out of your downloaded AVIs.
If you want to improve in that respect, head over to the CONVERT section left, and start reading the guides found under AVI to DVD. Then you'll begin to understand what really goes on behind Neros/Uleads curtains.
If not, buy convertx2dvd which does as good job as possible, convertíng almost anything thrown at it to Video DVD. Or buy a DVD player that supports DivX/XviD AVI playback, and just burn the AVIs as data to CD-R/DVD-R. The cost is about the same, but the latter solution is much simpler.
/Mats -
Nero and Ulead movie factory are converting to dvd video and dvd is another video format than avi divx/xvid and it requires bigger file size for equal quality.
But don't join, it can cause sync problems. Just add both clips in ConvertXtoDVD and convert to one DVD. -
Maybe you should convert it to a dvd format folder first, then it is easy to burn
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
