I want to copy Main Movie only, which contains two different screen formats, the full and wide. So I selected Re-author and then dragged the main movie with the DVD Shrink3.2. However, the choice of the screen format is in the Menu folder that cannot be re-authored. Do you know how to keep the choice of the screen format from the menu folder and the main move so that I can choose the different screen format? In other words, I only want to keep the choice of the screen format and main movie, the full and wide. Thank you for your answer.
You can rip the full disc and then use VobBlanker to blank whatever you choose not to keep.
Screen capture of live webcam stream - which format should I use?
By clemenzina in forum Video Streaming DownloadingReplies: 0Last Post: 23rd Nov 2011, 06:44 -
decoding FLV with screen video format
By killerhex in forum Video ConversionReplies: 1Last Post: 25th Nov 2010, 04:30 -
Capture Desktop screen on a streaming format?
By therock003 in forum Video Streaming DownloadingReplies: 4Last Post: 9th Feb 2009, 14:24 -
Canon HG10 Screen Format
By bill5 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 13th Aug 2008, 08:16 -
Need help on how to author a DVD w/clips into a small section of the screen
By mbextreme in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 05:22
