I am going to try this, since some movies I've obtained came in widescreen, and, I prefer fullscreen. I'll be using fairuse wizard 2.4, but would like to know how big I should set the file size for say a 2hr plus movie, longer, or, shorter.
I've done the reverse (avi to dvd,) and know that the file size of a dvd is larger since avi is a compressed file format. But my conversion programs for that automatically set the correct file size. But in reading the guide for fairuse, it doesn't appear that this program does the same when compressing. Or, does it?
If anyone can provide an answer to this, I greatly appreciate it.![]()
What is your goal with the avi divx/xvid? just watch on your computer? burn avis on cds? or reconvert to dvd again?
yes, to convert widescreen format to fullscreen, then burn the converted display format to DVD.
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 05:29 -
Convert DVd to xvid avi best quality for max size 900mb
By selwyns2828 in forum DVD RippingReplies: 6Last Post: 10th Feb 2011, 17:02 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 06:14 -
Question about avi file size limit for DVD players
By jimdagys in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Dec 2009, 03:12 -
batch convert avi's to DVD size
By milofhead in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 08:51
