Internet Explorer 7.0 causing delay to load media files in Windows Media Player 9, 10 & 11?!
Hello,
I recently installed WinXP PRO Engish SP-2, with all the latest updates, including Internet Explorer 7.0.
After I installed IE 7.0, I noticed that when using Media Player, there was a delay of -3-4secs to load a media file (Avi,Mpeg,DivX, Xvid, OGG, MKV…). This happens when a video file is all ready being played in media player. If I choose another media file using Windows Explorer browser or Total Commander, it will take 3-4secs longer to start in MP. I have installed all the latest DivX, Xvid, FFdshow, AC3, plug-ins and the same problem occurs in Media Player 9, 10 & 11.
Media Player Classic however shows no problems or delays.
I can verify that that this lag is caused by IE 7.0, as I reinstalled WinXP PRO (Without installing IE 7.0 this time) and there was no delay when loading media files in Media Players 9, 10 or 11. I then reinstalled IE 7.0 (No other WinXP update) and the exact same problem occurred!
My system:
Core2 Duo 6600 @2.4GHZ
1GB DDR-2 Kingston HyperX 800MHZ
SeaGate 7200 SATAII 500GB
Asus P5B-E M/B
Asus GeForce 7950GT 512MB
The exact same problem occurred on a different rig with newly installed WinXP Pro SP-2, IE 7.0 & Media Player 11:
P4 3.2GHZ
512MB DDR-1
GigaByte M/B
80GB SATA HD
So, is this a known problem and is there a way round to fix it?
Or should I just stick to Internet Explorer 6.0, as it does not cause the above problem.
Thanks in advance.
Results 1 to 1 of 1
Encode for lowest CPU load while playing in Windows Media Player
By IriTrisha in forum Video ConversionReplies: 8Last Post: 15th Apr 2012, 11:23 -
Flash Media Encoder Delay When Streaming
By skillednerd in forum Video Streaming DownloadingReplies: 0Last Post: 12th Apr 2011, 18:44 -
ıs Xvid 1.2.2 causing undersized files in AutoGK?
By Anonymous5394 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Mar 2010, 06:19 -
Unable to get Media Player classic to load subtitles.
By amax in forum SubtitleReplies: 6Last Post: 20th Oct 2009, 11:08 -
Media Player Classic won't load ffdshow - choppy video
By ioda006 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Jun 2009, 22:44
