For Windows. I see there is Cinelerra, but it apparently only runs on Linux.
I would want to keep the video in the same container/codec, just be able to edit it (cut segments) and write it back out losslessly. I don't mind limiting my cuts to Key Frames (which it appears are pretty far apart).
I assume that's not Ogg audio with a Xvid video? Since you mention Theora and Vorbis, likely not. That's what I run into most often.
This is still apparently the premier site for Theora and Vorbis: http://www.xiph.org/ If you haven't been there, maybe worth a look. -
MediaInfo gives me this (among other things) when I mouse over one of the files in question:
General #0
Format: Ogg
Video #0:
Codec: Theora
Width: 384
Height: 288
Aspect Ratio: 4/3
Frame Rate: 12.5fps
Writing Library: Xiph.Org libTheora I 20060526 3 2 0
Audio #0:
Codec: Vorbis
Channel(s): 2 channels
Sampling Rate: 22 KHz
Writing Library: Xiph.Org libVorbis I 20050304
Nothing but Linux-based stuff at Xiph.org. -
Other than the various command line tools, I can't think of anything for windows that supports ogg video.
Assuming the proper directshow filters are installed, you could run the file through Virtualdub with AviSynth (directshowsource) and make your segment cuts there. You still might be left with the problem of lossless output in the Theora format from there. VirtualDub could do a "direct stream copy" and will output to the OGM container. Could that not work - or at least be renamed to OGG afterwards? It's highly probable that I'm missing something here. The office coffee maker crapped on us this morning.
Excuse my inexperience with mixing Virtualdub and AviSynth with Theora. -
Originally Posted by celtic_druid
WebM and OGG Theora in FFMPEGX?
By simpleknight in forum ffmpegX general discussionReplies: 0Last Post: 25th Jan 2012, 13:36 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 18:37 -
OGG Files With Theora Video
By DeathStalker77 in forum Video ConversionReplies: 14Last Post: 27th Dec 2008, 18:32 -
discuss ogg theora techniques
By zoobie in forum Video ConversionReplies: 11Last Post: 25th Aug 2008, 12:32 -
Ogg Vorbis to xvid conversion
By mattr in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2008, 05:21
