I am attempting to help a friend convert files he recorded using the .dvr-ms format in his Windows MCE XP and I am running into a frame-rate issue I don't quite understand. I am new to using this container, so I will easily admit to not knowing much about it's guts (It's basically an .asf file, right?), even though I have read the wiki on it and associated postings. I have done research and not quite found the answers I need.
I guess the one question that would answer all issues is: Is the native frame-rate for Microsoft Home Theatre .dvr-ms recordings 23.976 fps? I am asking this because while the .mpg output from DVRMSTOMPEGGUI shows as having a 29.976 fps output in G-Spot, it appears to be a telecined 29.967. I say that because as soon as that .mpg is plugged into a program like AutoGK or StaxRip, when the file is initially parsed the program automatically does an IVTC on it and brings it to a 23.976 fps.
Am I doing something wrong in the initial conversion using DVRMSTOMPEGGUI? Is there a setting i am missing so that the file stays in a true 29.976? Or is that impossible b/c the file is natively recorded at 23.976? Or is this the result of a setting my friend is using in the initital recording that needs to be changed?
All help appreciated.
Results 1 to 1 of 1
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 23:49 -
Editing and rendering with multiple frame rates?
By vid83 in forum EditingReplies: 12Last Post: 2nd Mar 2011, 04:20 -
Question about Blu-ray frame rates
By Mentasm in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Sep 2008, 12:16 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 19:47 -
Encoding in Virtualdub: Do you have to worry about frame rates?
By FallenAngelII in forum Newbie / General discussionsReplies: 28Last Post: 7th May 2007, 12:15
