My Panasonic DVD Recorder ES10 died after not quite two years. It had the typical Power Supply issue. that is apparently a side effect of Panasonic craftsmenship. It is out of warranty and the Repair shop that Panasonic referred me to was going to charge $259 with a $59 deposit and a 15 day turn-around. That was ridiculous considering the machine only cost $189 new and a new version is available for much less than that. Based on other posts the part itself is no more than $4.
Has anyone sucessfully repaired their Recorder or had a repair shop do it for a practical amount?
Some info in this thread about a similar issue. Good Luck
https://forum.videohelp.com/viewtopic.php?t=306990 -
My ES10 went out completely last year about a month after the warranty expired. I put it in the closet with the intention of someday having it fixed. Early in Feb. I called Panasonic and was told the repair cost and almost chunked the unit. Luckily, I did a search of this site and found a posting by BOB108 dated Oct. 11, 2006 that exactly described my problem.
See:
https://forum.videohelp.com/viewtopic.php?t=306990&postdays=0&postorder=asc&start=60
I ordered the two capacitors and soldered them in over the weekend. Now I have my unit back in operation thanks to BOB 108's posting. It was a relatively simple 10 or 15 minute procedure that cost me less than $12 for the 2 capacitors + shipping and not the $130 the manufacturer wanted to do this job.
Panasonic DMR es10 working question
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2012, 19:02 -
No video displaying Panasonic DMR-ES10
By nocutename in forum DVD & Blu-ray RecordersReplies: 2Last Post: 22nd Jul 2010, 07:47 -
Panasonic DMR-ES10 - Audio Quality?
By Kryzon in forum DVD & Blu-ray RecordersReplies: 10Last Post: 29th Dec 2009, 20:17 -
Panasonic DMR-ES10 No recording
By TAMMU in forum DVD & Blu-ray RecordersReplies: 12Last Post: 22nd May 2008, 23:52 -
Panasonic DMR-ES10 Reviewed
By zorankarapancev in forum DVD & Blu-ray RecordersReplies: 42Last Post: 1st Apr 2008, 22:45
