Just installed ConvertXtoDVD and it doesn't recognize the avi files i have saved to my desktop. No problem with mpgs. Is there a setting I missed. A codec I need? Please advise.
Results 1 to 12 of 12
Okay, thanks. I did that and no new codecs are required. This is the first time I am using ConvertXtoDVD.
Go post your problem on the vso forum website
http://club.cdfreaks.com/forumdisplay.php?forumid=65&s=
Include a copy of the log and they will help you -
Huffyuv codec by any chance?
Do you have ffdshow installed?
Give us some details and we'll find an answer. As ConvertXtoDVD is based on ffmpeg, the supported and non supported codecs will be almost identical. -
Not sure where you downloaded your version from, but I don't seem to have that file as part of my ConvertXtoDVD installation. Did you download yours from VSO's website ?
Read my blog here.
Didn't mean to confuse the matter. I think the error file refers to the nero 7 that I previously had installed. It popped up when I tried to use canopus pro coder. I though I might run my avi file through procoder to see it helped convertXtoDVD identify my avi.
To answer your question, I downloaded ConvertXtoDVD from VSO's site. -
I am running a test now. I converted my avi in procoder to avi-dv. and it appears convertXtoDVD has accepted it for conversion.
We are awaiting the conversion to complete and start the burn -
The burn was successful, but....
DVD played okay in computer, but when i played in on my consumer dvd player, it would not load. -
I have tried several procoder settings of my avi's to obtain a DVD from convertXtoDVD that will play on my consumer DVD player. No success yet. I really need to figure this out. Any help would be greatly appreciated.
Once the avi is accepted by ConvertXtoDVD, then you can stop wasting time converting it again. It will have no influence over the output from ConvertXtoDVD from that point. If the disc isn't playing then you need to look at things. How are you burning it ?
Read my blog here.
Won't recognize disc
By totallylost1 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Jul 2011, 18:57 -
Computer won't recognize all my memory
By ricoman in forum ComputerReplies: 8Last Post: 1st Nov 2010, 16:28 -
TMPGEnc won't recognise avi, ConvertXtoDVD no subtitles!
By CaptainChaos in forum Authoring (DVD)Replies: 34Last Post: 26th Apr 2009, 10:59 -
New MKV File-convertxtodvd won't convert it.
By jbitakis in forum Video ConversionReplies: 17Last Post: 4th Feb 2009, 14:51 -
Just installed - won't recognize Real
By fisheye in forum ffmpegX general discussionReplies: 8Last Post: 20th Aug 2007, 02:45
