My PC's parameters:
Pentium 166 mhz, 64 MB RAM, 1.5 GB HD, Windows 2000
I need an animation program that is goog enough. For example GIMP that competes with Adobe Photoshop in their software area.
At first I intend to transform a 2D to 3D logo and to make it turns on its axis.
Thank you in advance!
You need a hefty CPU and 3-D card. That computer is not even in the ballbark.
I'm trying to remember what was used back in 1995 for logo effects.
Back then SGI equipment still dominated the field using software from Alias and Wavefront. That tradition has continued with Maya software for use in current generation PCs. Free versions of Maya exist for non commercial use but require at least P4 hardware.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7639525
http://www.learning-maya.com/tutorials.php
http://en.wikipedia.org/wiki/Computer_animation -
You might try AnimeStudio as it's a 2D animation app that has limited 3D capabilities.
Anim8or is pretty light weight and has some good features.
http://www.anim8or.com/
40 second animation
By Ken-B in forum Off topicReplies: 3Last Post: 24th Nov 2011, 08:23 -
Software to create 3d animation/video
By mukeshs in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2010, 16:47 -
StormCel Animation
By Noahtuck in forum Latest Video NewsReplies: 0Last Post: 26th Jun 2008, 21:09 -
Animation software - MAC vs PC
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2007, 23:55 -
vegas 5 animation
By gomez1 in forum Newbie / General discussionsReplies: 12Last Post: 15th May 2007, 21:27
