Hello...
I looking for the best way to convert ape files to mp3 files....
any suggestions?
thanks
pigmallet
thanks...I'll give them a try....
MAX does look complicated
thanks again -
XLD is quick, but you have to set the Prefs first. Thanks for the tip. According to wikipedia, Monkeys Audio only works in Windows. Maybe someone needs to send them an update.
Max only works in Tiger. I'm still using Panther. -
Neither CocoaMonkey nor xACT do APE->MP3 though xACT's coder has expressed an intention to add the function to an upcoming version.
How to burn or extract some CUE or APE files?
By diets in forum AudioReplies: 3Last Post: 21st Jan 2010, 10:43 -
.flac/.ape To MP3 | I want the Best Result ...
By Benygh in forum AudioReplies: 7Last Post: 12th Dec 2009, 10:12 -
.ape format how to convert to mp3?
By sumeshkri in forum AudioReplies: 5Last Post: 30th Sep 2008, 22:16 -
Problem with APE file
By Gregg in forum AudioReplies: 1Last Post: 3rd Sep 2008, 06:30 -
Cutting avi's with APE 3?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 12:35
