Anyone has any idea on how to join RM video files? Please help.
It doesnt seem to work for all RMs, and I dont have many RM files available right now to test it fully, but it can join RMs.
Try to use vobmerge,
i use it to merge Mpeg1 or Mpeg2 files.
It work fine, only thing to remember befor launching it :
rename extension of you files in .vob
then join then, and finaly rename the result file into .RM
Megamoks -
I tried vobmerge with the renaming trick. It merged into a larger file but only played back the first RM clip. So the properties of the clips may have been copied without changing to a larger merged size. Any idea??
Video Files, join video_ts and flash video
By Pumkinhead in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2011, 06:45 -
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 12:04 -
A simple program that will join groups of 4 or so video files?
By Toki_Wartooth in forum EditingReplies: 9Last Post: 3rd Jun 2010, 18:21 -
Join Video Files
By maxhugen in forum Newbie / General discussionsReplies: 4Last Post: 25th Nov 2009, 03:11 -
Vdubmod, cannot join 2 video files
By kidcash in forum EditingReplies: 7Last Post: 11th May 2008, 09:17
