Results 1 to 25 of 25
  1. Hi,
    i have a single .vob file which i would like to play on dvd player but i cannot burn it in Nero's DVd-video cause they say too big for ISO. when i try to manually create in UDF a video_ts and burn it, it doesn't play on my player either
    I'm sure the dvd is working fine because i get to choose chapters n' such when playing it with VLC
    what should i do?
    thanks
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    You need to author, try TDA, Ifoedit or ReJig.
    He's a liar and a murderer, and I say that with all due respect.
  3. Also, Say with Nero i burn a DVd-Video file (ie contain Audio_ts & Video_TS).
    Can i also put other data folders in it? if i were to play the video in the dvd player would the other non-video files affect the viewing? Is it advisable to do so?
    thanks
  4. Originally Posted by steveryan
    could u pls give more detailed instruction/tutorial links or something on how i can specifically achieve my purpose?
    i'm not familiar with video authorign softwares
    thanks
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    dvdauthorgui, add the vob and output. Burn then the video_Ts folder with Nero.
    if you want a nice menu use tmpgenc dvd author, click on it for guides.
  6. Originally Posted by Baldrick
    Thanks, i downloaded DVDauthorGUi
    but when i 'add title' it doesn't recognise .vob, it only recognise, mpeg with nav packeet or mpeg elementary streams. how do i add the .vob?
    I downloaded the trial TMG, i get the error:
    'The computer CPU does nto support the SSE extended instruction set
    Apr 2004
    Miskatonic U
    use VOB2MPG to demux the video/audio from the VOB, then author with these instead.
    As for adding data - you can create a new folder at the same level as the video_ts folder. It can be called pretty much anything you like, and you can put anything in it you need to. It is not advisable to put data or folders in the video_ts folder.
    Read my blog here.
  8. Originally Posted by guns1inger
    hi,
    does it mean i have to convert it to .mpg, then later convert it to .vob?
    i think that would take eons to convert on my slow pc, lol
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It isn't a conversion process, and shouldn't take more than 5 - 10 minutes on your system
    Read my blog here.
  10. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    The VOB contains an MPEG and perhaps some other things (like subtitles). Demuxing is almost as fast as just copying the file. It's not transcoding, as converting from AVI to MPEG, the video isn't processed at all.
  11. thanks, is there any software that can do the same that doesn't require a .NET framework(don't wish to install that)?
  12. Open the Vob in DGIndex. Go File->Save Project and Demux Video. That will give you the M2V Video, the Audio (AC3, probably), but no subs. They will then be ready to author (if DVD compliant) using just about any authoring program.
  13. Member steveryan's Avatar
    Jan 2003
    Manchester
    Demux your VOB with ReJig in IFO mode, then load the 2 files into DVDauthorGUi, easy.
  14. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    This site does have a tools section (see menu to your left) and in it a separate list for multiplexers and demultiplexers. Have a look at pgcdemux or rejig as alternatives.
    Read my blog here.
  15. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    IFO mode only works if you have an IFO....
    But if you use Rejig's "File" mode you can demux a naked VOB.
    You can then click its "DVDAuthor" mode and build a complete VIDEO_TS folder ready to burn.
    This must be about the simplest way, for single title, no menu.
  16. Member steveryan's Avatar
    Jan 2003
    Manchester
    Apologies, I did mean file mode. Bloody keyboard
  17. thanks guys, i couldn't figure out how to demx in rejig so i did it in DGindex. i followed the easiest suggestion and opened it in REjig's dvdauthor after demuxing. to have a menu, i suppose i have to learn authoring. is it difficult to learn it?
  18. Banned
    Nov 2005
    Hi,
    what should i do?
    thanks
    the problem is that the dvd spec allows for vob files that are a maximum of 1 gig each. how did you end up with a 3.5 gig vob? the reason i'm asking is because it might give a clue as to how to undo it.
  19. deadrats: thats a good qn! haha, but i have no ans for it because i downloaded it from torrent.
    btw, i tried running the video, it HAS NO SOUND = (
    i am trying to use DVDauthorGUI but get this error :
    Process aborted due to above error
    Error code #5
    There was an error in multiplexing the titles. One of the m2v files has 'end sequence codes' in it that must be removed in order for it to multiplex correctly. This could be caused by an mpeg joining program or something similar. Use restream to remove these 'end sequence codes'. (http://shh.sysh.de/restream.html) Please review the log for more detailed information.
  20. Sometimes if I don't have IFO I just use dvd2one. It creates new ones.
  21. btw, i tried running the video, it HAS NO SOUND = (
    If you're talking about the M2V that DGIndex created, it's not supposed to have sound. It's only video. You'll get sound after authoring.
    Open the M2V in ReStream, and in the lower left corner is the check box for Sequence End Codes. Uncheck the box and rewrite the stream. Then try authoring again.
  22. Member grannyGeek's Avatar
    Apr 2006
    Land of the Rising Sun
    PS to Baldrick's suggestion to use DvdAuthorGui -
    I'm using version 1.009, and it accepts Mpeg Elementary Streams,
    AND
    "Mpeg with NAV packets ( VOB, mpg, mpeg) "
    Does your version not include "vob" as an option, or is it that it can't open your file?
    grannyGeek ~~
    Antique Newbie
  23. @manono
    i did that & somehow there was again error during re-streaming.
    @grannyGeek
    it does not inclue 'vob' as an option.
  24. i did that & somehow there was again error during re-streaming.
    You got an error using ReStream? Then I'd say your video is corrupt and fit only for the Recycle Bin. You might try and author using Muxman (adding just the M2V and the AC3 audio), and see if the log (found afterwards in the root of the C Drive) gives you any additional information if it can't complete the mux either.
  25. i think i give up on this dvd. haha, thanks for all the help i learnt alot
