I was wondering if it is possible to make SVCDs which my standalone DVD player and widescreen TV will recognise as a 16:9 source and switch to widescreen automatically.
I have captured a widescreen source and made a good quality SVCD which plays perfectly, and in the correct aspect ratio, on my widescreen TV, but I have to switch it to widescreen manually. The original source makes my TV switch to widescreen automatically, and I would like it if this happened with the SVCD I have made.
I have captured it in 480x576 (PAL), 25 fps, using Huffy and VDub, then frameserved to CCE 2.5 and muxed with BBMpeg and burned using VCDEasy. Is there anything in these that I have to do to enable the automatic switching.
Many thanks,
Kevin.
Hi,
In the CCE->Encode Settings->Other Settings->Video->Video ->Aspect Ratio , set to 16:9, it will encode the mpeg with this signaling.
And in the bbmpeg, in the Video Stream settings, set the same in Aspect Ratio.
I'm not shure but not all DVD Players use this signaling correctly, I don't have a widescreen set, but the player didn't letterboxed the screen.
Thanks for that, I'll give it a try.
I knew it would be something simple like that.
Cheers,
Kevin.
auto-detect NTSC or PAL for VHS?
By matt9b in forum Capturing and VCRReplies: 17Last Post: 3rd Jun 2011, 03:28 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
A way to auto-make screen caps from videos?
By Scav2003 in forum MacReplies: 15Last Post: 20th Aug 2010, 00:05 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
How make auto-play jpg-foto-DVD for standalone DVDplayer?
By onidarbe in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Oct 2009, 03:20
